MuvMeBack21980s
Feb 26, 2024Follower
Sneaky Teens foiling Orbi Mesh Parental Controls
I paid for Parental Controls and created multiple profiles and then assigned my teenager's computer to a profile with "bedtimes". His computer keeps reappearing in my main Home profile that is always ...
Feb 26, 2024Guru - Experienced User
Be aware though, both Android and Apple devices and MAC Address Randomizers which may negate these controls.
CrimpOn
My sense is that MAC randomizing is simply incompatible with Access Controls. If Access Control is enabled and new devices are not allowed, then any time a WiFi device changes MAC address, it will be blocked. i.e. if the control works as designed, this will create chaos when devices change MAC addresses.
- FURRYe38Feb 26, 2024Guru - Experienced User
Hopefully that works.
I would set a IP address reservation for the devices in questions, with the MAC Address randomizer disabled. Then would need to keep them disabled while at home. If they enable the randomizer, would and should hopefully be blocked by the system.
