DCP4971
Nov 28, 2023Luminary
SPC - Pause does not work
I’ve bitten the bullet and resubscribed to SPC, the price was stupidly low, so, I thought I’d re-enable the basics that I need to complement the other parental controls I replaced SPC with a number o...
- Nov 29, 2023
Sorted with a factory reset. Bit annoying to need to reset, but, used the opportunity to revisit all my reserved IP ranges which were fine when I first set it up, but needed some tlc.
DCP4971
Managed to get to support. Waiting for a call from someone after chat convo.
DCP4971
Nov 29, 2023Luminary
- FURRYe38Nov 29, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
