DCP4971's avatar
DCP4971
Luminary
Nov 28, 2023
SPC - Pause does not work
I’ve bitten the bullet and resubscribed to SPC, the price was stupidly low, so, I thought I’d re-enable the basics that I need to complement the other parental controls I replaced SPC with a number o...
  • DCP4971's avatar
    DCP4971
    Nov 29, 2023
    Sorted with a factory reset. Bit annoying to need to reset, but, used the opportunity to revisit all my reserved IP ranges which were fine when I first set it up, but needed some tlc.
