Hannah123
May 10, 2022Initiate
SPC not working on Rax10
The router had gone off line and reset it turned on and the SPC CONTROL DOES NOT WORK AGAIN. Have reset the router, redownloaded the app and I'm not sure what else to do and I'M PAYING FOR IT. Can't c...
JDaddy
May 29, 2022Guide
Yeah, you should be able to get support, but you can't. You cannot if you do not have an entitlement contract purchased. So, thanks for stealing our money Netgear and not supporting your software products.
Thador
Jul 09, 2022Guide
This should be easy to fix. I’ve checked and my device is NOT using private browsing. I should be able to ignore uncategorized traffic.
