DCP4971
Aug 02, 2021Luminary
SPC VPN can be deleted
Hi all, I've just tried moving from Circle, that I really didn't like, to SPC, which does on the face of it seem much more integrated and so far seems to be tracking activity well. The issue I seem...
DCP4971
Aug 04, 2021Luminary
Actually, I think this isn't quire as bad as I thought, the Orbi app notifies me when the vpn has been removed. But, would be better if it wasn't possible at all..though we are then into the more complex profiles, but for £7 a month, perhaps that's what I'd expect for parental controls.
It does still seem like a better product than Circle though..
- CrimpOnAug 07, 2021Guru - Experienced User
My knowledge of "I-Things" is limited. This situation appears to be a consequence of the iPad having a single login, which has access to everything. This seems to be an enduring problem in the "I-World", for example:
You may want to experiment with something called Guided Access:
https://support.apple.com/en-us/HT202612
The sense I get is that Guided Access can create accounts on an iPad that are unable to do certain things, such as access network settings.
(Confession: after finding this link and having no iPad to try it on, my attention wandered. This may be no help at all.)
