kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
DarrenM
Aug 13, 2020Sr. NETGEAR Moderator
I will report this issue to the engineers.
DarrenM
kelvinkewl
Aug 25, 2020Star
Netgear!
This post is coming up on 2 months old. Where are you at with removing the forced advert you are making me see every time I login to my router?
