kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
Hayashida
Oct 03, 2020Guide
This feature is really nuts and totally not professional.
I found a workardound using an Ad Blocker. With "Ads killer Adblocker plus" for Chrome, you can add a filter below to kill the pop up.
192.168.0.1###circle-info-modal
I have never heard that you need an ad blocker for an admin menu in a router.
- FlakieOct 09, 2020Guide
Cheers, exactly the same in AdBlock.
