kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
dstdean
Nov 10, 2020Aspirant
I agree that this is a royal PITA and needs to be fixed.
DarrenM
Nov 11, 2020Sr. NETGEAR Moderator
Can everyone that is experiencing this issue list me the router model they have so I can report this to the engineers for each model.
Thanks
DarrenM
- AnonymousNov 11, 2020
Hi Darren
R8000 here
- JoeQ51Nov 11, 2020Initiate
Hi, Darren.
My model is a R6700v3
Joe
- badmsNov 13, 2020Initiate
R7000 with latest firmware (updated today) shows this ad.
I find it comical that the moderator here needs a list of models this ad is popping up on, when Netgear knows very well that this was a deliberate act.
- Dougie18Nov 13, 2020Tutor
Netgear acting like they don't know which routers have this Circle advertising.
- kelvinkewlNov 13, 2020Star
It's a common tactic to push the issue out. Ask for more data. They clearly know which firmware was built with this code. DarrenM What is the scheduled release date for the updated firmware? I need to update my case with the Better Busines Bureau. And follow other means of filing complaints, etc.
- SwervingLemonNov 28, 2020Aspirant
Hi, Darren. Another R8000 but a follow-on question:
Why can I not disable the WPS on this router? I can disable the PIN but the WPS is still advertised and exploitable regardless of security settings for WPS. The brute force prevention does nothing.
Firmware V1.0.4.62_10.1.74
I wanted to flash this to DD-WRT but the latest firmware claims that my .chk isn't compatible (it is).
- badmsNov 28, 2020InitiateSwervingLemon please make your own post so I don't get a bunch of email alerts on your unrelated question. Thanks!
- RonSmithDec 09, 2020Star
The only thing that worked for me was to use uBlock Origin to block the ad and the dim overlay. Certainly would have returned this to Costco if it was present a few years ago when I purchased it.
- nuaimatFeb 22, 2021Aspirant
Can you please remove this annoying pop-up!
I am still seeing it on my R6900P
- michaelkenwardFeb 22, 2021Guru - Experienced User
Nothing we can do about it.
You should know that this community is essentially a user-to-user venue with some input from a small band of Arlo techies.
Most of the answers come from fellow users who have no connection with Arlo. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want direct contact with Arlo, try the various channels in the Contact Us link below.
