kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
DickBartlett
Nov 12, 2020Aspirant
If you try to sign on to Orbilogin.com and you get a screen Enable Smart Parental Controls on Your Router, check your URL line to see if the site is "Secure".
My sight shows "Not Secure".
I found a CSRSS.exe file that is a trojan program. Netgear will not let you log on with CSRSS program running.
