kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
kujayhawk
Nov 24, 2020Tutor
The Amplifi mesh router with VPN is working great for me. A good alternative. If you buy a second Amplifi VPN router then you've got a hardware VPN solution for any connected device so you don't have to be limited to mobile devices and having to use the Teleport app.
CRhode
Nov 25, 2020Tutor
Thanks kujayhawk, I'll bear that in mind.
I notice our moderator friend is very quiet, as is the company in general...
