kelvinkewl
Aug 08, 2020Star
The "Enable Smart Parental Controls on Your Router" nag ad pops up EVERY time I login to my router.
Ever since I applied the V1.0.4.98_10.0.71 firmware update, I am presented with a ""Enable Smart Parental Controls on Your Router" pop-up every time I login. There is no checkbox to disable this ...
kujayhawk
May 22, 2021Tutor
Mine hasn't shown the ad pop up in months. I've got the R6700v3 router. A recent update must have removed it. I'm at firmware V1.0.4.106_10.0.80
- Organic_MarbleJul 24, 2021Aspirant
It's stupid that we have to do this, but you can block the ads on Firefox with Adblock Plus.
Click the Adblock Plus stopsign icon, then select "Block Specific Element on this Page", click the ad at the top, then click OK. Boom, the ad is gone. Repeat for the ad at the bottom if you use the Basic tab. That one has two individual fields you have to block.
