william1104
Feb 21, 2022Aspirant
Upgrade rbr20 to rbk852 (circle subscription)
I would like to upgrade my rbr20 to rbk852. I have circle subscription with my Netgear account. What I need to do for transferring the subscription to the new router? And can I use both router togethe...
Feb 21, 2022Guru - Experienced User
You can use the 2 systems together but not integrated. You'd run the RBK852 as primary and the RBR20 system in access point mode. You'd want the 2nd system using a different ssid and wireless channels to prevent intererence.
