cscott1's avatar
cscott1
Guide
Nov 15, 2021
Using Parental Controls to block Google Recommendations on Android TV?
Within the last year or so Google began placing obtrusive ads which they call recommendations at the top of the Android TV homescreen. I was wondering if anyone has used parental controls to block the ads and not the actual services and if so can you give me instructions on what domain to block thanks.
1 Reply
  • plemans's avatar
    Google does a great job of incorporating their ads using the same addresses as the content. Its made any level of ad blocking pretty challenging. Even for devices like pi-hole to do. I don't know of a decent way to do it with parental controls.
