BretD
Jul 18, 2017Administrator
Community Pages Update Feedback
NETGEAR's new Community Pages are live and we want your feedback. We want to thank the Community for feedback from our first live test in June.
We hope you'll take our survey and tell us wh...
w3wilkes
Jul 19, 2017Prodigy
Nice how message 1276 in this thread has to be scrolled from side to side to read it. The browser window is plenty wide to accomodate it. Would be nice if the "improved" community software used the available screen space.
Sandshark
Jul 21, 2017Sensei
Yep, still extremely poor use of space. The crap in the left column is just that. Put in on another page (where nobody will likely go) or at least get rid of it when reading messages (as it is gone for replying).
We need a "Read All", not just a "Read All Unread".
But the worst thing of all: Every old message thread has been re-opened for replies. I just replied to one where somebody added to a message more than a year old and I didn't even realize it till it was too late. While I sometimes feel you close threads too quickly, having them all open is even worse.
- SandsharkJul 23, 2017Sensei
Oh, and one more thing that's made even worse my the new format but has always bothered me.
Your moderators' incessant replys of "We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped..." Are unhelpful, coumterproductive, and often make them look silly.
They are unhelpful for an obvious reason. They answer nothing.
They are counterproductive because they elevate a thread to "unread" when there is no new relevent information. That puts them in the "read all unread" list.
And they make the moderator look silly because at least half the time it is obvious that no solution has been accepted because it is obvious no solution has been provided. If the moderator cannot tell that, then he/she is unsuited for the job. Of course, I suspect that someone in Netgear management is telling them to do this, since they all do it, so it is actually management that is silly. If this was only used when it is obvious that the OP has found a solution (sent a message like, "yes, that fixed it") but did not select the reply as a solution, I could tolerate it more.
- aksJul 24, 2017Virtuoso
I would prefer to see more community/forum thread information than the advertisments down the left using up real estate for mostly what I consider garbage. I read left to right, so it's annoying having extra rubbish on the left. If you really believe it to be valuable, then please locate it to the right, and minimise the intrusion in to the real data.
The fonts are covered already. Thread entry uses good clear fonts (actually a little on the large side). Preview and thread reading seems to change that and use poor unreadable fonts.
