BretD
Jul 11, 2018Administrator
COMPLETE: Planned Community System Maintenance August 29th - Posts/Replies Will be Disabled
Update: 8/29/2018 - 6:30AM PST
Matienence is complete for the NETGEAR Community Forums.
Please note that visiting an Arlo link will redirect you the Arlo Community Forum.
Update: 8/30/2018 ...
- Aug 29, 2018
BretD
Aug 07, 2018Administrator
Try going to the Android section fo the following link: https://whatsabyte.com/featured/your-connection-is-not-private/
w3wilkes
Aug 23, 2018Prodigy
Hopefully one of the things that will be fixed is to actually honor the "Keep me signed in" to the community check box. This has not worked for a long time and it's tiresome to have to log in every time I access the community.
- mdgm-ntgrAug 27, 2018NETGEAR Employee Retired
We sign you out automatically out of the community after a period of inactivity. This isn’t a bug but a deliberate choice we made.
- w3wilkesAug 28, 2018Prodigy
Kind of defeats the purpose of have a "Keep me signed in" check box. Maybe you should remove the check box if you're just going to ignore it or ad a disclaimer that says "We ignore this box if checked".
- BretDAug 28, 2018AdministratorThank you for your patience.
Maintenance is about to begin. Please stand by.
