BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
     The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
seanwang
Nov 01, 2017Initiate
Do you know where else i can buy this beside att.com?The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobile router. Now you can do anything you can do at home virtually anywhere you go. It’s battery powered router with Dual-Band Wifi 2.4/5GHz allowing up to 20 devices to connect to it.
Nighthawk® LTE Mobile Hotspot Router
Model: MR1100
TECHNICAL SPECIFICATIONS
• Max 1 Gbps download speeds & 150 Mbps upload speeds
• LTE CAT 16, 4-band CA and 4x4 MIMO
• Up to 4X Carrier Aggregation and LLA
• LTE/4G 1/2/3/4/5/7/12/29/30/66
• 3G 2/4/5
PHYSICAL SPECIFICATIONS
• Dimensions: 105.5 (L) x 105.5 (W) x 20.35 (H) mm
• Weight: 240 g (with battery)
• Battery: 5040mAh for up to 24 hours of use*
*24 hour battery life is achieved by the following worst case: stream YouTube for 1 hour followed by 30 minutes idle time and then repeat for over 24 hours
Do you have any questions for us about the Nighthawk LTE? Our experts would love to help if you leave a comment below.
