BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
argondick
Nov 02, 2017Tutor
Current issue being experienced with the M1:
When I have the device connected to a laptop, no battery, and plugged in using the included power adapter, the M1 will power-cycle frequently.
On a Win7 PC this power-cycle occurs 1-2 every 8 hours. On a Mac running High Sierra, it occurs every 1-2 minutes.
Resolution so far is to put the battery back in, disconnect from the power cable, and continue to use ethernet.
Bad power cable?
BretD
Nov 02, 2017Administrator
That definitely sounds like a power-cable issue. You should open a support ticket. Good luck!
