BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
     The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
argondick
Nov 02, 2017Tutor
Current issue being experienced with the M1:
When I have the device connected to a laptop, no battery, and plugged in using the included power adapter, the M1 will power-cycle frequently.
On a Win7 PC this power-cycle occurs 1-2 every 8 hours. On a Mac running High Sierra, it occurs every 1-2 minutes.
Resolution so far is to put the battery back in, disconnect from the power cable, and continue to use ethernet.
Bad power cable?
argondick
Nov 06, 2017Tutor
Sharing this update for awareness:
I submitted a trouble-ticket and was told that my device was constructed specifically for AT&T and I needed to take it back for an exchange to the nearest AT&T store. Not having that time available, I attempted other fixes.
I ended up seeing success by using the included power cable and plugging that USB into a 3rd-party USB cover plate - the kind you can pick-up at any hardware store and plugs into a standard outlet to provide a dual-USB charging platform. The particular device I'm using has 2 - 2.5v chargers and has been powering the M1 for 4 days straight now, without any power-cycling.
I did try various other chargers to determine if that was my cause, including a: 2.5v stand-alone, a 5.0v stand-alone, a 10w and 12.5w stand-alone - but all ended up power-cycling the device after a random period of time.
Not sure why the dual-USB outlet module works, but it has and continues to keep the device powered without a battery installed.
