BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
argondick
Nov 07, 2017Tutor
You have 2 options:
1. Download the Netgear App via the Google store or iPhone App store. Once installed, you'll have to connect to your Netgear Wifi with the admin credentials and then you can change the Administrative password.
2. Connect to the Netgear Wifi and navigate via web browser to ATTWIFIMANAGER.com or 192.168.1.1 and get to the web console. After logging in with the default admin crednetials, you can then modify the password as needed.
candelas1
Nov 18, 2017Aspirant
witch app? i am having the same problem want to change the passwork but cant figure out how to
