BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
911grizzly
Nov 27, 2017Aspirant
Two questions:
Is this mobile hotspot available (in the USA) only through AT&T, or if not which other carriers is it compatible? Related question: can it be purchased in an unlocked version?
Will this device work with the Netgear Smart Cradle DC 112A?
argondick
Nov 27, 2017Tutor
There is a Great Britain variety, but unsure of the carrier. Additionally, I have seen mention that the device accepts a T-Mobile SIM and will attach to that network.
You can buy an unsubsidized model through AT&T, then request the unlock code through their website. Usually within 48 hours, you’ll receive an emailed unlock code that can be entered.
- argondickNov 27, 2017TutorAlso - not sure about the cradle. I bought the Netgear TS-9 antenna and hooked it up to the Netgear via exposed antenna ports. Used Ethernet to connect to an Apple AirPort Extreme and it works well enough.
- 911grizzlyNov 30, 2017Aspirant
I bought this unit from AT&T, requested and received the unlocking code. AT&T also provided this helpful advice: " Unlock instructions: Contact your manufacturer if you have additional questions."
I found the Netgear User manual for this device (80+ pages), but it does not appear to contain any unlocking instructions. I submitted an email support ticket to Netgear for help (not easy to do by the way, the website is not user friendly) and I'm waiting to hear back.
- Wandaa21Nov 30, 2017AspirantThank you! I spoke with AT&T store today, and He recommended I hook it up to a router and then hard wire it to the Xbox, to see if that works!! I will try and get an unlock code from AT&T! It shouldn't be this difficult......
- 911grizzlyNov 27, 2017Aspirant
That’s helpful, thanks!
Can anyone tell me about compatibility with the cradle? I need the cradle to boost the output (big house) and to connect to an external antenna (remote area).
