BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
argondick
Nov 27, 2017Tutor
There is a Great Britain variety, but unsure of the carrier. Additionally, I have seen mention that the device accepts a T-Mobile SIM and will attach to that network.
You can buy an unsubsidized model through AT&T, then request the unlock code through their website. Usually within 48 hours, you’ll receive an emailed unlock code that can be entered.
argondick
Nov 27, 2017Tutor
Also - not sure about the cradle. I bought the Netgear TS-9 antenna and hooked it up to the Netgear via exposed antenna ports. Used Ethernet to connect to an Apple AirPort Extreme and it works well enough.
