BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
argondick
Nov 28, 2017Tutor
Also - not sure about the cradle. I bought the Netgear TS-9 antenna and hooked it up to the Netgear via exposed antenna ports. Used Ethernet to connect to an Apple AirPort Extreme and it works well enough.
911grizzly
Nov 30, 2017Aspirant
I bought this unit from AT&T, requested and received the unlocking code. AT&T also provided this helpful advice: " Unlock instructions: Contact your manufacturer if you have additional questions."
I found the Netgear User manual for this device (80+ pages), but it does not appear to contain any unlocking instructions. I submitted an email support ticket to Netgear for help (not easy to do by the way, the website is not user friendly) and I'm waiting to hear back.
- Wandaa21Dec 01, 2017AspirantThank you! I spoke with AT&T store today, and He recommended I hook it up to a router and then hard wire it to the Xbox, to see if that works!! I will try and get an unlock code from AT&T! It shouldn't be this difficult......
