BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
911grizzly
Nov 30, 2017Aspirant
I bought this unit from AT&T, requested and received the unlocking code. AT&T also provided this helpful advice: " Unlock instructions: Contact your manufacturer if you have additional questions."
I found the Netgear User manual for this device (80+ pages), but it does not appear to contain any unlocking instructions. I submitted an email support ticket to Netgear for help (not easy to do by the way, the website is not user friendly) and I'm waiting to hear back.
Wandaa21
Thank you! I spoke with AT&T store today, and He recommended I hook it up to a router and then hard wire it to the Xbox, to see if that works!! I will try and get an unlock code from AT&T! It shouldn't be this difficult......
