BretD
Oct 27, 2017Administrator
Nighthawk LTE Mobile Hotspot Router – Gigabit WiFi on the Go – AT&T Networks
The wait is over! Experience fast premium WiFi on the go, with the Nighthawk Mobile Hotspot Router on AT&T. You can take it with you! The Nighthawk LTE Mobile Hotspot Router is your ultimate mobi...
Gdgtgrl
Apr 30, 2018Aspirant
I purchased the Nighthawk LTE Mobile Hotspot Router, MR1100, from AT&T. The first unit started powering down ramdomly after using it a few days. I have it set to not go to sleep. To get it to turn back on, I need to pop the battery out, put it back together and then press the power button to restart. I exchanged the unit on the 14th day for a new one. It started out fine and after a bout a week, It is again powering down unexpectedly and I need to remove/ reinsert the battery to get it to reboot. The frequency of power offs is increasing. Any ideas? I checked for updates and it is on the current software version available.
MelanieM1
Jun 05, 2018Initiate
When we can expect a new Firmware for the M1 with fixes?
So long time ago since last Update and Support don´t answer that question.
currently Version 12.02.07.00 the lastest Version for Nighthawk M1 Aircard MR1100-100EUS.
Thanks
