BretD
Aug 30, 2017Administrator
Orbi Pro WiFi System - Tips, Tricks and Resources
     We designed Orbi Pro to be simple anyone can set it up and use it immediately. But, it never hurts to get a few hints and tips to get you started on your path to awesome and easy to use small bus...
BretD
Sep 08, 2017Administrator
Orbi Pro – Tip 1: Orbi Pro can create 3 separate independent WiFi SSID names. This is perfect for business as it allows you to share one Broadband Internet connection over WiFi with different types of users ranging from first - System Administrators, second - Employees and finally - Customers. Each access level provides a different set of rules so your network can stay safe and secure, yet available to everyone.
BretD
Orbi Pro SRK60 Ceiling and Wall Mounting Instructions
Orbi Pro Tip #2 - We know your business needs to be flexible, so Orbi Pro can be mounted just about anywhere! The package contains both Wall and Ceiling mounting hardware and anchor screws. See the Orbi Pro quick install guide for DIY mounting instructions.
