HappyCat
Jan 06, 2026Luminary
Cannot Paste Images
When I attempt to Reply to a post and attempt to paste an image from the Windows Clipboard, a message comes up, "Media Upload in Progress. Please try again in a few moments." (I would post a screen ...
- Jun 29, 2026
Yes, this problem appears to have been solved!
CrimpOn
Jan 06, 2026Guru - Experienced User
Trying to investigate a problem with the Community Forum. For YEARS I have used "cut and paste" to insert images into Forum posts. Recently, every time I attempt to do this a message pops up at the bottom of the screen saying "Media Upload in Progress. Try again in a few moments." This happens when using Chrome, Edge, Firefox, and Opera web browsers. Tried to use the "Insert Media" (camera icon) and the same thing happened. Tried to make an attachment, which disappeared. (Attachments are not nearly as "user friendly" as cut and paste.)
So, the question is:
- Is there a problem with the Forum software that it no longer allows images in posts? or....
- Is there a problem with my account (or my computer?) that I am no longer allowed to include images?
It would be helpful if some of you could Reply to this post and include any sort of image.
Thanks
CrimpOn
Oh, NO. Logged in using a different Forum identity (HappyCat) and was able to create a Reply with an image pasted into it. (HappyCat is not an Insider, so I cannot access this conversation using that identify.) There is also now a post from HappyCat that will "make no sense" because all it contains is an image, and I cannot delete a post. Hmm. guess I should go and Reject it?
did so.
