HappyCat
Jan 06, 2026Luminary
Cannot Paste Images
When I attempt to Reply to a post and attempt to paste an image from the Windows Clipboard, a message comes up, "Media Upload in Progress. Please try again in a few moments." (I would post a screen ...
- Jun 29, 2026
Yes, this problem appears to have been solved!
CrimpOn
Jan 06, 2026Guru - Experienced User
Trying to investigate a problem with the Community Forum. For YEARS I have used "cut and paste" to insert images into Forum posts. Recently, every time I attempt to do this a message pops up at the bottom of the screen saying "Media Upload in Progress. Try again in a few moments." This happens when using Chrome, Edge, Firefox, and Opera web browsers. Tried to use the "Insert Media" (camera icon) and the same thing happened. Tried to make an attachment, which disappeared. (Attachments are not nearly as "user friendly" as cut and paste.)
So, the question is:
- Is there a problem with the Forum software that it no longer allows images in posts? or....
- Is there a problem with my account (or my computer?) that I am no longer allowed to include images?
It would be helpful if some of you could Reply to this post and include any sort of image.
Thanks
CrimpOn
using Brave to post this image:
So, Chrome, Edge, Firefox, and Opera browsers all would not accept a pasted image, but the Brave browser DID
A major difference is that in order to log on using Brave I had to erase all history. (which I do NOT want to do with the other browsers.... or should I?)
