HappyCat
Jan 06, 2026Luminary
Cannot Paste Images
When I attempt to Reply to a post and attempt to paste an image from the Windows Clipboard, a message comes up, "Media Upload in Progress. Please try again in a few moments." (I would post a screen ...
- Jun 29, 2026
Yes, this problem appears to have been solved!
Jan 20, 2026Guru - Experienced User
NG is aware of it. Said to have a fix forth coming, though no date to when that will happen.
Something to try for those of you who want to post pictures while we all wait for NG to fix this, can use a cloud service to save your pictures too. Then use the DIRECT IMG link feature to copy. Select the Camera icon on the post tool bar, then select FROM IMG URL. Paste in the DIRECT IMG url link. The picture or image should appear in the post.
Example:
