Sandshark's avatar
Sandshark
Sensei
May 09, 2025
Community/My Community pull-down issue
When I select Community and then My Community from the header drop-down, it takes me to a page where it says to select my community, but there are none from which to select.  All I see is this feedback area, but with only the ability to read, not start a new subject.  There is a whole lot of white space on the left where something is probably supposed to be.
  • Hello Sandshark​!
    Thank you for pointing this out. I think this should be fixed now. Can you please confirm?
    Keep the feedback coming! :-)
    Kind Regards,
    Christine
  • ChristineT's avatar
    ChristineT
    NETGEAR Employee Retired
    Hello Sandshark​!
    Kind Regards,
    Christine
    • Sandshark's avatar
      Sandshark
      Sensei
      Yep, it now goes to a page where I can make a selection, including this one.
