Sandshark
May 27, 2025Sensei
More on unread messages
OK, so here is another issue with unread messages. This message says it has 2 replies: ReadyNAS Pro 6 - Stuck on booting while checking fs | NETGEAR Communities. But there is only one visible, so t...
Sandshark
May 29, 2025Sensei
I suspected as much, which means the software has a bug. Your SUGGESTED work-around would certainly be welcome, but the root cause should also be fixed.
May 30, 2025Guru - Experienced User
Sandshark wrote:Your SUGGESTED work-around would certainly be welcome, but the root cause should also be fixed.
Agreed.
