snacker
Dec 14, 2025Aspirant
Prevent IPv6 Tracking (RFC 4941/ 8981)
Do any of the NetGear WiFi Routers implement RFC 4941 or RFC 8981 to prevent IPv6 tracking of internal devices? Or are there any Netgear WiFi Routers that allow you to disable IPv6 altogether? ...
CrimpOn
Dec 14, 2025Guru - Experienced User
Every Netgear router I have seen has IPv6 as optional. Turn it on (or off). User choice
The user manual for the RS500 (page 36) has a description of packet inspection done when IPv6 is enabled.
- StephenBDec 14, 2025Guru - Experienced User
True, but this does NOT address the concerns raised in RFC8981, which are focused on tracking, not on blocking inbound connections.
