schumaku
May 07, 2025Guru - Experienced User
Quoting and Private Messages doesn't work
A major step back.
Can't find much excitement here.
Access from full browsers does not work
Quoting is broken, new editor is a mess -we do NOT need DESKTOP PUBLISHIBG EDITOR. PM system broken (...
schumaku
May 08, 2025Guru - Experienced User
Dear Christine
Under some conditions, the authentication or session cookies seem to be ignored, or the processing of these does fail partially.
Some investigations are ongoing, valid authentication cookies will be ignored, depending on the Internet connection in use. Could be some ISP DNS filtering and/or the co-existence of ipv4 and ipv6.
Since there are no obvious error messages or blocking messages from the isp security guard, we must troubleshoot the issue together with Netgear IT.
Have tried calling you yesterday, but was not able to establish a call successfully.
On the road these hours, and the 4G Internet connection seems to allow it as of writing
Thank you for activating eg the Edit option, it's workable now.
-Kurt.
