schumaku
May 07, 2025Guru - Experienced User
Quoting and Private Messages doesn't work
A major step back.
Can't find much excitement here.
Access from full browsers does not work
Quoting is broken, new editor is a mess -we do NOT need DESKTOP PUBLISHIBG EDITOR. PM system broken (...
schumaku
Jun 06, 2025Guru - Experienced User
ChristineT wrote:Just to close the loop on the "quoting" feature. It appears the platform has been "enhanced". To use the "Quote this" follow the steps below:
Click Reply
Highlight as much text as applicable from the original post that you want to quote.
Click the Quote this Icon that should appear above the highlighted text.
Please confirm if these steps fix the quoting issue
xxxx
Sandshark wrote:That does work, in part. But note that the numbering in your list wasn't included in the quote because it won't highlight. And if I try to add the numbering back with the numbered list button, it is shown as just one item.
xxxx
ChristineT wrote:Kind Regards,
Christine
ChristineT wrote:Click Reply
Text structures like bullet lists and numbered lists, as well as special formatting like bold text are -not- taken over as part of the quote. Compare with your original post:
ChristineT wrote:Hello schumaku and StephenB ,
Just to ...
User references are also not taken over as part of the quotes, Back again to Khoros for yet another rework and fix please.
At least, it appers the login from dual-stack clients seems to be workable again, thanks CrimpOn for the notification of commuinication with ChristineT
