schumaku
May 07, 2025Guru - Experienced User
Quoting still broken
Despote the promised, quoting is still INOP.
I would expect EF. while posting a reply, clicking on the " (quoting) should import the full content to reduce or redact if needed while replying on.
ChristineT
May 07, 2025NETGEAR Employee Retired
Hello schumaku ,
The system gives you 30 minutes to edit your post. Since you are an experienced user, I have extended the ability to edit your posts to be unlimited.
I'm still looking into the "quoting" feature and will provide an update once I learn more.
Best,
Christine
Sandshark
May 08, 2025Sensei
No, it does not. There is no edit option.
- schumakuMay 08, 2025Guru - Experienced User
Test reply.
Edit is workable again, ok for my account at least. However not for earlier posts for users with special privileges.
Inline images still can't be added however. Not even s single attachment.
- SandsharkMay 08, 2025Sensei
I do not (yet?) have any special privileges and cannot edit any message I've posted at any point in time. At this point, I think it's good I have no special access, as I can evaluate what a standard user sees.
