Bioman800's avatar
Bioman800
Code pin verrouillé sur Netgear M1: comment faire lorsque le mobile ne peut se connecter au routeur
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Also try here:
    Français - NETGEAR Communities
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • ValerieD's avatar
    ValerieD
    Community Manager
    Bonjour Bioman800,
    Et bienvenue sur la Communauté NETGEAR! :)
    Si vous saisissez trois fois un code PIN incorrect, la carte SIM est bloquée. Si la carte SIM est bloquée, contactez votre fournisseur d'accès pour recevoir un numéro PUK afin de débloquer la carte SIM.
    Bonne journée à vous,
    Valérie D
    Equipe Netgear
