Ozersensei
Mar 04, 2024Aspirant
Nightawk M6 - Chargeur non reconnu
Bonjour, Je viens d’acheter un routeur Nightawk M6 (MR6150) et il ne se charge pas. Aussi lorsque je branche l’appareil sans sa batterie il affiche le message : « Use the supplied power adapte...
Retired_Member
Mar 04, 2024the User Manual says only to plug the included USB-C cable into the included AC adapter. (or laptop port).
there's no info about the adapter, like its charging power, or if it's the Quick Charge (QC) or Power Delivery (PD) type.
so that's all the info they share.
plug it in and it should work.
else it's broken.
https://www.downloads.netgear.com/files/GDC/MR6500/MR6500_MR6110_UM_FR.pdf
https://www.downloads.netgear.com/files/GDC/MR6500/MR6500_MR6110_UM_EN.pdf
