Thierryblain
Oct 22, 2021Initiate
RBR 350 connection d'un disque dur
Bonjour, Je viens d'installer un routeur RBR 350, sur une freeboox et je n'arrive pas à connecter un disque dur au reseau. merci de vos conseils. Cordialement Thierry
Oct 22, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
