PATITE
Mar 25, 2025Follower
Rbs50 anneau routeur violet fixe
Bonjour L'anneau du routeur reste en violet fixe alors que mon PC qui est connecté au wifi de ce routeur a bien accès à internet Je ne sais pas quoi faire car d'après le guide d'utilisation cela sig...
KevinLiT
Mar 25, 2025NETGEAR Moderator
Hello PATITE,
Welcome to the NETGEAR Community!
I understand that you are having issues connecting your RBS50 to your RBR50. This issue is most likely a result of the RBR50 being on a different firmware than the RBS50. Please connect an ethernet cable to the back of the RBS50 then navigate to orbilogin.com to update your satellites firmware. Then bring your satellite within 5 feet of your Orbi router and re-sync it to your network.
Please navigate to the link below for a video tutorial on how to update your Orbi satellite:
Please navigate to the link below for additional information on updating your Orbi Mesh system:
Best,
Kevin
Community Team
