Pat49
Feb 18, 2024Aspirant
screenshot Netgear A 6150 wifi
hello, I would like my iPad to be able to serve as a screenshot of my PC. Is this possible using Netgear A6150 wifi? If so, how should we do it. Thank you for your help. (NETGEAR A 6150 Wifi)
michaelkenward
Feb 18, 2024Guru - Experienced User
Screenshot? What does that mean? What are you trying to do?
The A6150 is a USB adapter. It allows you to connect a PC to wifi.
Pat49
want my tablette to serve as a repaeter when i drive my Sailing Boat while my PC remains on the chart table inside
- michaelkenwardFeb 18, 2024Guru - Experienced User
Sounds complicated. Not the sort of application that comes naturally to domestic network devices.
More like something I would expect bluetooth to handle.
What is the tablet? iOS? Windows? Android?
What is the PC? MacOS? Windows?
Where is the Internet connection coming from?
