Aragorn2lyon
Mar 03, 2022Follower
Configuration Freebox Revolution / R7000p / EX8000
Bonjour à tous, Voilà j'ai une maison à étages et j'ai progressivement fait l'acquisition d'un R7000P puis récemment d'un EX8000. Ma connexion Internet provient d'une Freebox Revolution en Fibre...
Mar 03, 2022Guru - Experienced User
If dhcp is enabled on the freebox, you should either have the r7000p in access point mode or the ip address for the r7000p in the freebox's DMZ.
Also, the EX8000 uses a dedicated wireless backhaul between the router and the extender. If you log into the ex8000, you should be able to see the status of that backhaul. The fronthaul (what devices connect to) can be great but if the backhaul is poor, they're not going to get a connection to the router. So take a look at that. There might be something between the 2 floors interfering with the wifi signal and causing issues on the backhaul.
