Pat_DEM
Jul 10, 2024Aspirant
What is the default password of the French version ? It starts with "Mot..." and I cant see the end
michaelkenward
Jul 10, 2024Guru - Experienced User
Password for what?
Wifi? Admin access?
Which device?
Something to do with the section you have posted in, the Nighthawk app?
Apologies for the questions. That's what you get when you try to stuff everything into the subject line. Do that and you can't provide enough detail to get quick answers.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- Pat_DEMJul 10, 2024Aspirant
orry !
My question is about Nighthawk application on smartphone, French version.
It starts with "Mot...." but I can't see the end as my display is not large enough.
I tried many solutions with MotdePasse, MotPasse, MotdePasseAdmin, etc. without success.
My question is about Nighthawk application on smartphone, French version and is for admin login
- michaelkenwardJul 10, 2024Guru - Experienced User
Tried password?
The app uses the same admin credentials as a web browser and the graphical user interface (GUI). And that is on the device itself.
The admin username is admin. You can't change it on most devices.
We still don't know which device you are trying to control with the app.
Try:
Français - NETGEAR Communities
Your question: Tried password ? (MotdePasse, MotPasse, MotdePasseAdmin, etc. )
Answer: Yes
My question is about the default password of Nighthawk app on Android smartphone
