JoFeRoGo's avatar
JoFeRoGo
Cannot connect
Hello,   I bought a Meural MC315 and I can't connect with the Android app! I always get the same message "The canvas is already saved" "...it seems that your work area has been set up with anothe...
  • schumaku's avatar
    Dec 25, 2021
    Soit vous demandez à la boutique où il était affiché de le supprimer de son compte, soit vous devez contacter le support client Meural. Rien que la communauté puisse réparer.
