Ronaldotheone
Aug 27, 2024Aspirant
Ipv4 openvpn netgear
how to connect to open von connect the error message is "ipv6": false and I want to connect in ipv4
Ronaldotheone
Yes, think you for your response
Netgear R6120
Netgear R6120
Ronaldotheone
Oui ipv6 est désactivé
- FURRYe38Aug 27, 2024Guru - Experienced User
Please review this:
- RonaldotheoneAug 27, 2024AspirantIl n'y a pas d'accès au vpn c'est une vielle version
Merci furry- FURRYe38Aug 27, 2024Guru - Experienced User
Might try updating FW.
Router model is fairly old and may need to find a newer generation router that has better VPN support.
