Real2101
Jun 23, 2023Tutor
configurer un r6900 en mode répéteur sur un netgear r7200
Hello, I replaced my r6900 router with a more recent r7200 but I would like to use my r6900 in repeater mode to extend the reach to my garage. There is a function in advanced configuration of the r6...
- Jun 23, 2023
Real2101 wrote:
but it must surely have a way to configure it, ....
I'm afraid there is no "surely" about it.
If the manual for the R7200 doesn't describe it, then it won't work.
You may be able to find third party firmware that breaks Netgear's rules.
Over the years Netgear has played with different approaches to which routers do and don't offer various bridge/repeater options. If anything it has reduced the number of routers with these "exotic" configuration options.Things like Mesh technology exist to provide better wifi coverage over an area.
AP mode is pretty well the only constant in Netgear routers and DSL modem/routers, something that cable modem/routers can't handle without messing around.
One way to repurpose spare routers is to resort to Powerline Ethernet and AP mode. Given the right circumstances, especially a decent mains circuit, it could even be better than any mode that relies on a WiFi link back to the router.
microchip8
Jun 23, 2023Master
NETGEAR firmware does not support Repeater mode.
- michaelkenwardJun 23, 2023Guru - Experienced User
The R6900 and R7200 both support WiFi Bridge mode.
- microchip8Jun 23, 2023MasterRepeater != Bridge
microchip8 wrote:
Repeater != BridgeNo, but it might help Real2101 to achieve what they want.
People have been known to confuse things, and even to find that there are other ways of getting where they want t be.
It is always useful to provide as much information as possible.
- Real2101Jun 23, 2023Tutor
yes the r6900 model has the function in the advance options but not the r7200, I want to know how to configure the r7200 so that it sees the r6900 in repeater mode, I want to repeat the wifi, as a bridge, we can use the wired ports
- schumakuJun 23, 2023Guru - Experienced User
This does make a WiFi client out of the R6900, and allows to bridge the R6900 LAN ports to the other network. This won't make a wireless repeater where you can also associate WiFi clients to.
Look in the user manual of the r6900 page 179 and you will understand what I want to do, I have already done it with two r7000 and it is easy, only enter the mac address of the repeater in the router of which serves as a base and that of the base mac address in the repeater, but on the r7200 the function is not there but it must surely have a way to configure it, Both have their firmware up to date
