Nathan8413
Nov 25, 2025Aspirant
Absence de wifi
Bonjour à tous, J'ai branché mon routeur M60 et je l'ai connecté via Ethernet au routeur de mon fournisseur d'accès à internet. J'ai suivi toutes les étapes de l'application Nighthawk. Qu...
Nov 25, 2025Guru - Experienced User
Nathan8413 wrote:The LED on the front of the device is flashing white continuously!
Per the manual (page 10):
- https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
The router LED pulses white for one of the following reasons:
- You connected the power adapter to the router. Now the router is booting and
attempting to sync with the satellite. - You pressed the Sync button and the router is attempting to sync with the satellite.
- You pressed the Reset button and the router is resetting to its factory default settings.
Did you set up the satellites? Or do you just have the main router?
Can you connect to the router's web page from a PC (connected with ethernet, since wifi isn't working).
