Minipouch
Oct 24, 2025Aspirant
Déconnections intempestives de mon Orbi RBRE960
Bonjour, Depuis que j'ai mon système Orbi RBRE 960 et 2 satellites, j'ai plusieurs dizaines de déconnections par jour. Au début je pensais que c'était mon opérateur (VOO Belgique) qui provoquait...
Minipouch
Hello,
I haven't tried using wireless backhaul with the satellites. But I'll give it a try.
Do you mean the port speed of my ISP modem or the internet speed I have at home? My home speed is 200 Mbps and the port is 1000 Mbps. My Ethernet cables are Cat-7.
Thank you for your help.
Oct 24, 2025Guru - Experienced User
Minipouch wrote:the port is 1000 Mbps. My Ethernet cables are Cat-7.
Ok. The 960's WAN port is 10 gbps. So one possibility is that there is a negotiation problem (or a cabling issue) between the modem and the router. I don't think that's likely with Cat-7 cabling though.
FWIW, I have an old Cat-5e running to my router WAN port (installed in the wall, so hard to replace). This misbehaved with my 870. I worked around it by putting a small gigabit switch on the path. So if you happen to have a switch handy, you could try using that.
But I have seen other reports of wired backhauls not working well, so I think you should try that test first.
This could also be a faulty WAN port in the 960, so you could try exchanging it if you are still in the return window. Exchanging with the seller is usually easier than getting an RMA from Netgear support.
- MinipouchNov 06, 2025Aspirant
Bonjour,
j’ai fait plein de tests. Rien n’a fonctionné.
J’ai essayé le firmware 7.2.6.31 et là, tout est devenu stable. Plus de redémarrage. Mais mes appareils ios se déconnectent tout le temps. J’ai lu que la plus stable était la 7.2.6.21 mais il est indiqué que elle n’est pas faite pour l’Europe (je suis en Europe). Dois-je mettre la 6.x.x.x?
merci
