bounia
May 03, 2023Aspirant
RBR350 satellite non connecté quand RJ45 connecté
Bonjour, je possède depuis 2021 un système RBR350 routeur + 3 satellites. Un de mes satellites (appareillé sans fil) ne se synchronise pas quand un cable RJ45 est branché dessus. J'ai plusieurs a...
CrimpOn
May 04, 2023Guru - Experienced User
Yes, 4.4.1.29 is the most recent firmware listed on the support web page.
The RBS350 has only two Ethernet ports, which is what causes customers to connect a switch to the satellite in order to provide enough ports for their devices.
"Completely different" IP address in what sense? Surely not in a different IP subnet?
"Static IP" in the sense that
- IPs are reserved in the LAN setup table?
I, also, have nearly every device in my house assigned to a specific IP address, including the Orbi satellites. - IPs are defined on the device itself. I try to avoid that.
Identifying which device connected to the switch is causing the problem may be required.
I would employ a binary search:
- Disconnect half of the devices and restart.
- If the problem occurs, then the disconnected devices are not responsible.
- Disconnect half of the remaining devices.
- Continue until the device is identified.
One of those devices may include a DHCP server. When the satellite powers up, it broadcasts a DHCP request for an IP address and will accept the first response it gets. (I notice a Raspberry Pi is one of the devices. My Pi is running Pi-hole, which includes a DHCP server that I have disabled.)
Oui, 4.4.1.29 est le firmware le plus récent listé sur la page web d'assistance.
Le RBS350 n'a que deux ports Ethernet, c'est pourquoi les clients doivent connecter un switch au satellite afin de disposer de suffisamment de ports pour leurs appareils.
Adresse IP "complètement différente" dans quel sens ? Certainement pas dans un sous-réseau IP différent ?
"IP statique" dans le sens où
* Les IP sont réservées dans le tableau de configuration du réseau local ?
J'ai également assigné une adresse IP spécifique à presque tous les appareils de ma maison, y compris les satellites Orbi.
* Les IP sont définies sur l'appareil lui-même. J'essaie d'éviter cela.
Il peut être nécessaire d'identifier l'appareil connecté au switch qui est à l'origine du problème.
Je ferais une recherche binaire :
* Déconnecter la moitié des appareils et redémarrer.
* Si le problème survient, les appareils déconnectés ne sont pas responsables.
* Déconnectez la moitié des appareils restants.
* Continuez jusqu'à ce que l'appareil soit identifié.
L'un de ces appareils peut être un serveur DHCP. Lorsque le satellite s'allume, il émet une requête DHCP pour une adresse IP et accepte la première réponse qu'il reçoit. (Je remarque qu'un Raspberry Pi fait partie des dispositifs. Mon Pi utilise Pi-hole, qui comprend un serveur DHCP que j'ai désactivé).
bounia
May 08, 2023Aspirant
Hi CrimpOn,
thanks for the advise, I tried the binary search and I identified what was causing the issue. On of the switch was connected a CPL plug that was propagating the wifi to the front gate where the Orbi wifi could not be reached.
The CPL (a TP-Link) was the cause of the issue. I'm now triyng to reserve the IP in the LAN table of Orbi router.
Do you know if there is a known issue caused by a CPL plug behind one of the satellites?
Thanks.
Bastien
Merci pour les conseils. J'ai essayé la recherche binaire et j'ai identifié ce qui causait le problème. Sur l'un des switchs était connectée une prise CPL qui propageait le wifi jusqu'à la porte d'entrée où le wifi de l'Orbi ne pouvait pas être accessible.
Le CPL (un TP-Link) était la cause du problème. J'essaie maintenant de réserver l'IP dans la plage LAN du routeur Orbi.
Savez-vous s'il existe un problème connu causé par une prise CPL derrière l'un des satellites ?
Je vous remercie.
Bastien
