Afajr's avatar
Afajr
Follower
Feb 21, 2026
Probleme caméra
Bonjour j’ai des problèmes avec ma caméra et j’aimerais changer le channel sur mon routeur AX6
merci
1 Reply
  • StephenB's avatar
    merci
    AX6 is a performance rating, not a specific model.  It'd be useful to know exactly what model router you have.
    As far as channel goes, are you wanting to disable a band (2.4 ghz or 5 ghz)?  If not, then in what band is the channel you want to change?
