Afajr
Feb 21, 2026Follower
Probleme caméra
Bonjour j’ai des problèmes avec ma caméra et j’aimerais changer le channel sur mon routeur AX6
merci
1 Reply
merci
AX6 is a performance rating, not a specific model. It'd be useful to know exactly what model router you have.
As far as channel goes, are you wanting to disable a band (2.4 ghz or 5 ghz)? If not, then in what band is the channel you want to change?
