marko160971's avatar
marko160971
Follower
Dec 13, 2012
ata1.00: configured for UDMA/133...
bonjour à tous,
je me demande en regardant la log system de mon ultra 4, pourquoi mes 4 disques durs western digital serie red,
sont-ils configurés en UDMA/133 alors que c'est du SATA?
Quelqu'un peut-il me répondre ?
merci par avance.
log ci-dessous:
Dec 12 19:28:12 NAS kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 12 19:28:12 NAS kernel: ata1.00: ATA-9: WDC WD30EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 12 19:28:12 NAS kernel: ata1.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
Dec 12 19:28:12 NAS kernel: ata1.00: configured for UDMA/133
Dec 12 19:28:12 NAS kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD30EFRX-68A 80.0 PQ: 0 ANSI: 5
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Dec 12 19:28:12 NAS kernel: sda: sda1 sda2 sda3
Dec 12 19:28:12 NAS kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 12 19:28:12 NAS kernel: usb 2-1: new high speed USB device using ehci_hcd and address 2
Dec 12 19:28:12 NAS kernel: scsi6 : usb-storage 2-1:1.0
Dec 12 19:28:12 NAS kernel: usb 2-2: new high speed USB device using ehci_hcd and address 3
Dec 12 19:28:12 NAS kernel: scsi7 : usb-storage 2-2:1.0
Dec 12 19:28:12 NAS kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 12 19:28:12 NAS kernel: ata2.00: ATA-9: WDC WD30EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 12 19:28:12 NAS kernel: ata2.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
Dec 12 19:28:12 NAS kernel: ata2.00: configured for UDMA/133
Dec 12 19:28:12 NAS kernel: scsi 1:0:0:0: Direct-Access ATA WDC WD30EFRX-68A 80.0 PQ: 0 ANSI: 5
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] Write Protect is off
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Dec 12 19:28:12 NAS kernel: sdb: sdb1 sdb2 sdb3
Dec 12 19:28:12 NAS kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Dec 12 19:28:12 NAS kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 12 19:28:12 NAS kernel: ata5.00: ATA-9: WDC WD30EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 12 19:28:12 NAS kernel: ata5.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
Dec 12 19:28:12 NAS kernel: ata5.00: configured for UDMA/133
Dec 12 19:28:12 NAS kernel: scsi 4:0:0:0: Direct-Access ATA WDC WD30EFRX-68A 80.0 PQ: 0 ANSI: 5
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] 4096-byte physical blocks
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] Write Protect is off
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Dec 12 19:28:12 NAS kernel: sdc: sdc1 sdc2 sdc3
Dec 12 19:28:12 NAS kernel: sd 4:0:0:0: [sdc] Attached SCSI disk
Dec 12 19:28:12 NAS kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 12 19:28:12 NAS kernel: ata6.00: ATA-9: WDC WD30EFRX-68AX9N0, 80.00A80, max UDMA/133
Dec 12 19:28:12 NAS kernel: ata6.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
Dec 12 19:28:12 NAS kernel: ata6.00: configured for UDMA/133
Dec 12 19:28:12 NAS kernel: scsi 5:0:0:0: Direct-Access ATA WDC WD30EFRX-68A 80.0 PQ: 0 ANSI: 5
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: [sdd] 4096-byte physical blocks
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: Attached scsi generic sg3 type 0
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: [sdd] Write Protect is off
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Dec 12 19:28:12 NAS kernel: sd 5:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
ProSupport for Business
